[mapguide-users] deleting feature source
Kencana bluesky_dyx at hotmail.com
Wed Mar 19 01:53:45 EDT 2008
Hi Jacky,
I only want that particular user to see the marker added by themselves not
other user's.
Regards,
Kencana Kesuma
Jackie Ng wrote:
> Just to clarify, is this a shared feature source for temporary features?
> You want other user's to see temporary features inserted by all users?
> What you could try to do is alter the feature class to include an extra
> property: User
> When a user adds a temporary marker to the map, include that user's id as
> part of the new feature.
> You can then hook onto the onunload javascript event to invoke a
> server-side script to remove all features from that feature source where
> the [User] is the ID of the user who just closed the web app.
> Hope that helps.
> - Jackie
> Kencana wrote:
>> Hi all,
>> Is that possible to delete the feature source when user leave the map web
>> app?
>> Previously, I used one feature source to draw the temporary layer,
>> however when there are more than 1 user using the map application at the
>> same time, the marker will be either missing or it is pointed to another
>> location. therefore, i decided to create one unique feature source for
>> each user who visits the map app. it solves the missing marker issue, but
>> i believe it is not the correct solution for this, as it keeps create new
>> feature source it will take more server storage. Any idea for solving
>> this problem?
>> Thank you
>> Regards,
>> Kencana Kesuma
View this message in context: http://www.nabble.com/deleting-feature-source-tp16112200s16610p16137536.html
