[mapguide-users] deleting feature source
Jackie Ng jackie.ng at aecsystems.com.au
Thu Mar 20 07:52:54 EDT 2008
Instead of your regular resource id string (ie
Library://Path/To/yourfeaturesource.FeatureSource ), use a session-based
resource id string instead (ie
Session:yoursessionid//yourfeaturesource.FeatureSource )
Just remember that resource ids are just references, so you have to
create/upload the underlying resource data itself.
- Jackie
Kencana wrote:
> Hi Jacky,
> can I know how to store the feature source into session repository?
> Regards,
> Kencana Kesuma
> Jackie Ng wrote:
>> I see, why don't you store the feature source into the session repository
>> as well? Session-based resources are temporary and get cleaned up when
>> that particular session has expired.
>> - Jackie
>> Kencana wrote:
>>> Hi Jacky,
>>> I only want that particular user to see the marker added by themselves
>>> not other user's.
>>> Regards,
>>> Kencana Kesuma
>>> Jackie Ng wrote:
>>>> Just to clarify, is this a shared feature source for temporary
>>>> features? You want other user's to see temporary features inserted by
>>>> all users?
>>>> What you could try to do is alter the feature class to include an extra
>>>> property: User
>>>> When a user adds a temporary marker to the map, include that user's id
>>>> as part of the new feature.
>>>> You can then hook onto the onunload javascript event to invoke a
>>>> server-side script to remove all features from that feature source
>>>> where the [User] is the ID of the user who just closed the web app.
>>>> Hope that helps.
>>>> - Jackie
>>>> Kencana wrote:
>>>>> Hi all,
>>>>> Is that possible to delete the feature source when user leave the map
>>>>> web app?
>>>>> Previously, I used one feature source to draw the temporary layer,
>>>>> however when there are more than 1 user using the map application at
>>>>> the same time, the marker will be either missing or it is pointed to
>>>>> another location. therefore, i decided to create one unique feature
>>>>> source for each user who visits the map app. it solves the missing
>>>>> marker issue, but i believe it is not the correct solution for this,
>>>>> as it keeps create new feature source it will take more server
>>>>> storage. Any idea for solving this problem?
>>>>> Thank you
>>>>> Regards,
>>>>> Kencana Kesuma
View this message in context: http://www.nabble.com/deleting-feature-source-tp16112200s16610p16177080.html
