[mapguide-users] DB XML Component Error in Dynamic Theming
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Mar 20 10:29:57 EDT 2008
When that error comes, there is usually an entry in the error.log file,
which indicates why the Xml was invalid.
This message will hopefully help you in locating the precise problem.
Regards, Kenneth, GEOGRAF A/S
Rahul skrev:
> Hi,
> I tried the *1.2 Viewer Samples* but unable to get going and the
> same error -*DB XML Component* Error coming up in the application.In
> the same application i can perform theming on some sdf files and
> cannot perform on other files. On the other hand when i tried to do
> _theming in the MapGuide Studio 2008_ , i can perform the same theming
> on the the layers with out any error.i am stuck and unable to move
> forward,how to resolve this Issue.
> Thks
> Max
> ----- Original Message ----
> From: Jackie Ng <jackie.ng at aecsystems.com.au>
> To: mapguide-users at lists.osgeo.org
> Sent: Wednesday, March 19, 2008 8:17:55 AM
> Subject: Re: [mapguide-users] DB XML Component Error in Dynamic Theming
> If I recall:
> 1 - The Generic Tasks sample was built for MGOS 1.1.0
> 2 - I think there were schema changes to LayerDefinition in MGOS 1.2.0
> Maybe try the 1.2 viewer samples, as are basically the updated version of
> the Generic Tasks sample.
> - Jackie
> max_samart wrote:
> > Hi ,
> > Thanks for your reply,i am using MGOS 1.2.0 ,yeh the exception
> shows
> > that not enough elements to match content model , Anyway i will try to
> > stylize the layer using the mapguide studio and capture the xml output
> > but what i use for the validation of the LayerDefinition document.
> > Thks
> > Max
> <mailto:jackie.ng at aecsystems.com.au>>
> <mailto:mapguide-users at lists.osgeo.org>
> > Sent: Monday, March 17, 2008 10:25:43 PM
> > It sounds like the layer definition xml does not validate. Are you
> able to
> > capture the xml output of the theme layer and see if it is a valid
> > LayerDefinition document?
> > Also, what version of MapGuide are you using?
> > - Jackie
> > max_samart wrote:
> >> Hi All,
> >> I have some sdf files as Polygons and when i want to use the
> >> Dynamic Theming(GT Example), its use to give mgdbxmlexception error,
> >> although I can do dynamic theming on some other sdf layers in the
> map but
> >> on some layers i am getting exception with pid terminated with exit
> >> status'0' .Can anybody give some idea reagarding the same in order to
> >> proceed further .
> >> Thks
> >> Max !!
> >> ERROR IN THE MAPGUIDE SERVER
> >> <2008-03-18T14:43:57> Officer Error: An exception occurred in DB XML
> >> component.
> >> Error: XML Indexer: Parse error in document at line, 61, char 12.
> Parser
> >> message:
> >> Not enough elements to match content model
> >> '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
> >> StackTrace:
> >> - MgResourceServiceHandler.ProcessOperation line 80 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
> >> - MgOpSetResource.Execute line 109 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\OpSetResource.cpp
> >> - MgServerResourceService.SetResource line 728 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ServerResourceService.cpp
> >> - MgRepositoryManager.SetResource line 867 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\RepositoryManager.cpp
> >> - MgRepositoryManager.AddResource line 840 file
> >> - MgResourceContentManager.AddResource line 183 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
> >> - MgResourceContentManager.PutDocument line 624 file
> >> - MgResourceDefinitionManager.PutDocument line 554 file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
> >> An exception occurred in DB XML component.
> Parser
> >> message: Not enough elements to match content model :
> >> ERROR in the WebServer-
> >> [Tue Mar 18 14:43:20 2008] [warn] FastCGI: (dynamic) server "D:/Program
> >> Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe"
> >> (pid 4088) terminated with exit with status '0'
> >> [Tue Mar 18 14:43:37 2008] [error] [client 10.0.y.y] FastCGI: server
> >> "D:/Program
> Files/MapGuideOpenSource/WebServerExtensions/Php/php-cgi.exe"
> >> stderr: PHP Fatal error: Uncaught exception 'mgdbxmlexception' in
> >> Unknown
> >> on line 0, referer:
> >> http://10.0.x.x:8008/mapguide/Officers/theme/thememain.php
> >> [Tue Mar 18 14:43:57 2008] [error] [client 10.0.z.z] FastCGI: server
> >> "D:/Program
> >> Unknown
> >> on line 0, referer:
> ____________________________________________________________________________________
> >> Never miss a thing. Make Yahoo your home page.
> >> http://www.yahoo.com/r/hs
> >> mapguide-users mailing list
> >> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > View this message in context:
> http://www.nabble.com/DB-XML-Component-Error-in-Dynamic-Theming-tp16117523s16610p16118026.html
> > Sent from the MapGuide Users mailing list archive at Nabble.com
> <http://nabble.com/>.
> > Be a better friend, newshound, and
> > know-it-all with Yahoo! Mobile. Try it now.
> > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> http://www.nabble.com/DB-XML-Component-Error-in-Dynamic-Theming-tp16117523s16610p16135228.html
> Looking for last minute shopping deals? Find them fast with Yahoo!
> Search.
> <http://us.rd.yahoo.com/evt=51734/*http://tools.search.yahoo.com/newsearch/category.php?category=shopping>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080320/143ed384/attachment.html
