[mapguide-users] Fusion with jsp
Kenneth, GEOGRAF A/S
ks at geograf.dk
Fri Mar 28 09:48:32 EDT 2008
Even though there is no .Net or JSP implementation for Fusion, you can
still use the MapGuide API to work with mapguide in .Net or JSP.
It is only if you need to modify/interact with the Fusion server side
scripts that you need a ported version.
You can read the sessionID from Fusion, and use that when you open the
connection.
Regards, Kenneth, GEOGRAF A/S
Ivan Milicevic skrev:
> I don't thing that there is jps version of fusion just like .NET.
> You'll have to rewrite existing PHP code to jsp.
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
> *Abdrabba Yassine
> *Sent:* Friday, March 28, 2008 11:35 AM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] Fusion with jsp
> Hi,
> I'm developing a web application with mapguide using the JAVA Web
> extensions API, and for the viewer i want to use the Fusion Viewer.
> My question is how i can implement functionality that requires direct
> access to the MapGuide Server. Because as I know the additional
> functionality is
> implemented only in PHP on top of the MapGuide Web Tier API.
> Could anyone tell me where I can find a JSP implementation.
> thank you in advance.
> Abdrabba Yassine
> Blog: http://a-yassine.blogspot.com
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080328/e595f631/attachment.html
