[mapguide-users] Getting Started Site Admin Problem
    Jason Birch
    Jason.Birch at nanaimo.ca
    Fri Mar 28 11:31:48 EDT 2008
Jackie wrote:
Re: Trac tickets. I'm of the belief you should file tickets regardless of
how trivial they are. Worst case: it gets closed and forgotten, best case:
someone will actually look at it ;-)
I agree with this, but it is important to put as much information into the ticket as possible so that, even if it is not immediately reproducible (and fixable) by the developers, additional reports can be correlated with the initial one to track down the variable that is causing the problem.
Jason
