[mapguide-users] Newbie needs help with project to query web
layouts
Kenneth, GEOGRAF A/S
ks at geograf.dk
Fri May 2 02:53:17 EDT 2008
You have to wait until the map has loaded, because the viewer creates
the runtime map that you want to query.
Once the map has loaded, you can access the runtime map, and set the
selection.
You will need some javascript like this:
<!-- Javascript part -->
<script type="text/javascript">
var mapFrame = null; // A reference to the map frame
var originalMapFrameOnSelectionChanged = null // storage for the
original onSelectionChanged function
function OnSelectionChanged() // when something is selected on the map
alert('Your handler works perfectly');
originalMapFrameOnSelectionChanged();
function InitDocument()
var win = document.getElementById('viewerFrame');
if (win.contentWindow) //FF returns the actual tag, IE returns
the iframe
win = win.contentWindow;
mapFrameRef = win.GetMapFrame();
mapFrameRef.parent.OnSelectionChanged;
mapFrameRef.parent.OnSelectionChanged =
OnSelectionChanged;
function RetryInit()
if (mapFrame != null)
return;
try
InitDocument();
//At this point, you can post a "PageLoaded" via a form or AJAX
catch (e)
mapFrame = null;
if (originalMapFrameOnSelectionChanged == null)
mapFrame = null;
window.setTimeout("RetryInit();", 500);
</script>
<!-- HTML part -->
<html>
<body>
<iframe id="viewerFrame" frameborder="yes" width="100%" height="60%"
src="
src="../mapviewernet/dwfviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>""
onload="RetryInit()"></iframe>
</body>
</html>
Regards. Kenneth, GEOGRAF A/S
Nick Aizen skrev:
> Can anyone help me with this process, I'm new to both web development
> and MapGuide API development, so please excuse me if I don't ask my
> question the correct way but basically....
> I want to be able to load a weblayout (created in MG Studio), when my
> asp.net page loads and query and zoom on the map in the weblayout
> before the page is fully displayed. Basically I will be calling the
> asp.net page from an application passing it parameters for the query
> functionality.
> I would appreciate it if someone can provide a code snippet. I'm
> using as my base, one of the examples provided on the Autodesk web
> site. I can provide any information regarding the project being used
> if that will help. Also, other than the PDF's provided my Autodesk are
> there any helpful resources for developers?
> Here's the code when the page loads that loads a weblayout:
> MgUserInformation userInfo = new MgUserInformation("Administrator",
> "admin");
> MgSite site = new MgSite();
> site.Open(userInfo);
> String sessionId = site.CreateSession();
> String webLayout = "Library://DevTV/HelloWorld.WebLayout";
> 'Need help with API to query and zoom'
> Then the layout is passed to the viewer.
> <frameset rows="0,*" border="0" framespacing="0">
> <frame />
> <frame src="/mapguide2008/mapviewernet/ajaxviewer.aspx?SESSION=<%=
> sessionId %>&WEBLAYOUT=<%= webLayout %>" name="ViewerFrame" />
> </frameset>
> Many Thanks,
> *Nick Aizen*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080502/ac919fad/attachment.html
