[mapguide-users] MGOS 2.0 and IIS 7
Darrin Maidlow dmaidlow at landorgis.com
Sun May 4 16:45:12 EDT 2008
Thanks to my workstation deciding its days were numbered, and having to get
a shiny new one with 4GB ram.  I was forced to suffer through two days of
'fun' getting vista x64 running.
I documented the process of getting the web tier running on 64 bit IIS 7.
The process should be the same for 32 bit (minus the part where you need to
setup the app pool to run in 32 bit mode).  I've documented it here:
http://www.webrade.com/blogs/darrin/2008/05/01/ManuallyConfigureMapguide2009
WebTierOnVistaX64IIS7.aspx
Though its untested, I suspect the same steps will apply to a 64 bit windows
2008 install as well.
hopefully this helps someone.
darrin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tim Strang
Sent: Wednesday, February 06, 2008 9:21 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] MGOS 2.0 and IIS 7
I have tested with the IIS6 compatibility mode (add/remove programs, choose
add/remove Windows components tab on the left) a while back. It was working.
I haven't looked at this in a recently, so I don't know if it is still
working. It is worth a shot.
Tim
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, February 06, 2008 11:10 AM
I don't think it's likely that the MapGuide web server extensions will
be able to install to IIS7...  If you don't mind hacking around, you
_may_ be able to get it to work, but I doubt that it will be easy.
Jason
Subject: [mapguide-users] MGOS 2.0 and IIS 7
     I'd like to try MGOS 2.O, but I'm not sure it will work in my
laptop.
     I'm running Windows Vista (IIS 7) and my intention is create some
ASPNET applications using Microsoft Visual Studio 2008.
     Do you see any problems?
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
