[mapguide-users] Newbie needs help with project to query web -Thanks Kenneth, GEOGRAF one more question please?
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon May 5 02:08:47 EDT 2008
I belive you must call Save on either the Selection or the Runtime map
(can't remember which).
Regards, Kenneth, GEOGRAF A/S
Nick Aizen skrev:
> You’re idea helped me get over one obstacle, but I now seem to have
> one more. Below is my code from Deafult.aspx.
> <%@ Page Language="c#" Debug="true"  %>
> <%@ Import Namespace="OSGeo.MapGuide" %>
> <%@ Import Namespace="System" %>
> <%@ Import Namespace="System.Text" %>
> <%@ Import Namespace="System.IO" %>
> <%@ Import Namespace="System.Collections.Specialized" %>
> MapGuideApi.MgInitializeWebTier(@"C:\Program
> Files\Autodesk\MapGuideEnterprise2008\WebServerExtensions\www\webconfig.ini");
> MgUserInformation userInfo = new MgUserInformation("Administrator",
> "admin");
> MgSite site = new MgSite();
> site.Open(userInfo);
> String sessionId = site.CreateSession();
> String webLayout = "Library://DevTV/HelloWorld.WebLayout";
> Globals.gSessionID = sessionId; //Holds my session ID value
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
> <html>
> <body>
> <iframe id="viewerFrame"  width="100%" height="1000px"
> src="/mapguide2008/mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>"onload="OnMapLoaded()"></></iframe>
> <iframe style="display: none" src="" id="maploaded""></iframe>
> <script>
> function OnMapLoaded()
>    document.getElementById('maploaded').src = 'maploaded.aspx';
> </script>
> </body>
> </html>
> Code in maploaded.aspx
> <%@ Page Language="C#" %>
> <script runat="server">
>     MgGeometry getGeometry(String district, MgFeatureService
> featureService)
>         MgFeatureQueryOptions districtQuery = new MgFeatureQueryOptions();
>         districtQuery.SetFilter("Autogenerated_SDF_ID = " + district);
>         MgResourceIdentifier districtId = new
> MgResourceIdentifier("Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource");
>         MgFeatureReader featureReader =
> featureService.SelectFeatures(districtId, "VotingDistricts",
> districtQuery);
>         featureReader.ReadNext();
>         MgByteReader geometryBytes = featureReader.GetGeometry("Data");
>         MgAgfReaderWriter agfReader = new MgAgfReaderWriter();
>         MgGeometry districtGeometry = agfReader.Read(geometryBytes);
>         return districtGeometry;
> </script>
>     String sessionId = Globals.gSessionID; //Global from Default.aspx
>     String district = "3";
>     String name = "ELSO";
>     string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
>     String configPath = realPath + "webconfig.ini";
>     MapGuideApi.MgInitializeWebTier(configPath);
>     MgUserInformation userInfo = new MgUserInformation(sessionId);
>     MgSiteConnection siteConnection = new MgSiteConnection();
>     siteConnection.Open(userInfo);
>     MgResourceService resService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>     MgFeatureService featureService =
> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
>     MgMap map = new MgMap();
>     map.Open(resService, "Sheboygan");
>     //Get Geometry object: districtGeometry
>     MgGeometry districtGeometry = getGeometry(district, featureService);
>     MgFeatureQueryOptions nameQuery = new MgFeatureQueryOptions();
>     nameQuery.SetFilter("RNAME LIKE '" + name + "%'");
>     nameQuery.SetSpatialFilter("SHPGEOM", districtGeometry,
> MgFeatureSpatialOperations.Inside);
>     MgResourceIdentifier parcelId = new
> MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource");
> featureService.SelectFeatures(parcelId, "Parcels", nameQuery);
>     //Highlight the query result on the map
>     MgSelection selection = new MgSelection(map);
>     MgLayer layer = (MgLayer)map.GetLayers().GetItem("Parcels");
>     featureReader = featureService.SelectFeatures(parcelId, "Parcels",
> nameQuery);
>     selection.AddFeatures(layer, featureReader, 0);
>     String selectionXML = selection.ToXml();
> <html xmlns="http://www.w3.org/1999/xhtml" >
> <head runat="server">
>     <title>Untitled Page</title>
> </head>
> <script type="text/javascript">
>         function onPageLoad() {
>             var selectionXML = '<%= selectionXML %>';
>             parent.SetSelectionXML(selectionXML);
>     </script>
> </html>
> When the map comes up, nothing is selected…..you’ve been such a “HUGE”
> help, could you review what I have and give me you opinion please…many
> thanks.
> *Nick Aizen*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080505/d64ed7d3/attachment.html
