[mapguide-users] Newbie needs help with project to query web
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon May 5 15:56:53 EDT 2008
In the last line, try replacing:
String selectionXML = selection.ToXml();
with:
selection.Save(resService, "Sheboygan");
And instead of the JavaScript SetSelectionXml, try to do only a map refresh:
parent.GetMapFrame().Refresh();
If it does not work, can you post the string you get from
"selection.ToXml();"?
Regards, Kenneth, GEOGRAF A/S
Nick Aizen skrev:
> Do you have any code snippets on how and when to do this? My process
> was taken from andf online example provided by Autodesk and the
> process works when the selection code is called from a button click
> and  save is never called, which leaves me to wonder.."Am I doing
> something wrong?" I don't think I'm even effecting the viewer at all.
> Anyway...thanks for the help.
> *Nick Aizen*
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080505/f4db9cde/attachment.html
