[mapguide-users] Determine if Layer is a Raster Layer
Andy Morsell
amorsell at spatialgis.com
Tue May 6 12:18:22 EDT 2008
You can also try looking at the results of
MgLayerBase::GetFeatureGeometryName() function
http://mapguide.osgeo.org/files/mapguide/docs/webapi/d5/db1/class_mg_layer_b
ase_1397670802efc84d2fc0a93cac61b3d0.htm#1397670802efc84d2fc0a93cac61b3d0
It will return "Image" for the Autodesk raster provider and "Raster" for the
GDAL provider.
Here's some example code.
$map = new MgMap();
$map->Open($resourceService, $this->args['MAPNAME']);
$layers = $map->GetLayers();
for ($i = 0; $i < $layers->GetCount(); $i++)
$layer = $layers->GetItem($i);
echo($layer->GetFeatureGeometryName());
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
Sent: Tuesday, May 06, 2008 8:03 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Determine if Layer is a Raster Layer
Look at the xml content of the layer definition.
Raster layers have the root element of GridLayerDefinition
Vector layers have the root element of VectorLayerDefinition
- Jackie
Adnan Chughtai wrote:
> Hello All,
> Currently working with the API for MapGuide OpenSource 2.0 and have an
> issue with determining with a Layer is a Raster Layer. I am using the
> OSGeo FDO Provider for Raster
> In MapGuide 6 - the method getLayerType() returned a string denoting
> the layer type, e.g Polyline, Polygon, Raster, etc.
> In MGOS 2.0, the method getLayerType() returns an int with two
> possible values 2 -Basemap or 1 - Dynamic. Is there a method in MGOS
> 2.0 API that does a similar function as the getLayerType which is in
MapGuide 6?
> Regards,
> Adnan
> mapguide-users mailing list
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context:
http://www.nabble.com/Determine-if-Layer-is-a-Raster-Layer-tp17084050p170848
56.html
