[mapguide-users] MapGuide studio expired
Jackie C. Ng
jumpinjackie at gmail.com
Tue May 6 21:58:46 EDT 2008
.net 1.1 applications can run on a v2.0 installation.
The reason that .net framework 1.1 is required is because that is what the
installer is checking for as part of installation (because the source code
targets v1.1)
You can either:
1 - Install .net framework 1.1 OR
2 - Download the zip distribution instead. You should be able to run the
binaries without problems.
- Jackie
Viva_Rose wrote:
> Hi Jackie,
> Yes it returned the list of resources in xml format. I'm running 2.0 .NET
> framework in my pc but the mapstudio that u recommend to me using 1.0.0
> .NET framework. Is it will cause a problem to me? I'm really new in this
> gis area and lack of experience..Help me ....
> Jackie C. Ng wrote:
>> MapGuide Studio does not hold your spatial data hostage. You should be
>> able to access through alternate means.
>> If you go to the mapagent test pages
>> (http://yourservername/mapguide/mapagent/index.html) and choose the
>> EnumerateResources method, does it return a list of resources in xml
>> format?
>> - Jackie
>> Viva_Rose wrote:
>>> Hello,
>>> I've install the mapguide studio into my PC to load shp file into the
>>> web application. Unfortunely when the studio application expired, all
>>> the data layer that i used to generate into web are disappear. Wat
>>> should i do?
>>> I've try to run webstudio open source but the webstudio are not
>>> working.The page look this everytime i try to load any shp file (refer
>>> to attachment). Really hope someone can help me to solve this problem.
>>> http://www.nabble.com/file/p17078652/prob.bmp prob.bmp
> :confused::confused::confused::confused::confused:
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/MapGuide-studio-expired-tp17078652p17093713.html
