[mapguide-users] Problems with featureservice.UpdateFeatures
Zac Spitzer zac.spitzer at gmail.com
Wed May 7 01:24:52 EDT 2008
i ran into it a while back it's a 2.0 thing and several people have
had the same issue on the list
On Wed, May 7, 2008 at 3:22 PM, Scott Hameister <scotth at mpower-tech.com> wrote:
> That makes sense..haven't found it yet tho...is that a change you know of between 1,2 and 2.0 or just an experience you've had... I want to nail this down for good.
>  -----Original Message-----
>  From: "Zac Spitzer" <zac.spitzer at gmail.com>
>  To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
>  Sent: 5/6/08 8:35 PM
>  Subject: Re: [mapguide-users] Problems with featureservice.UpdateFeatures
>  you have previously opened a feature reader and not closed it
>  On Wed, May 7, 2008 at 4:01 AM, Scott Hameister <scotth at mpower-tech.com> wrote:
>  > I created a buffer tool in 1.2…that let you create a new buffer and type in
>  > the name of the layer you wanted it on.
>  > I would then check to see if the layer already existed then delete out any
>  > objects inside to clean it out before adding to it.
>  > The codes still works fine in 1.2…but in 2.0 I get this Error
>  > Please Try your Operation Later Resource was busy Sesion:134….
>  > I'm working in Coldfusion, but the code should translate fairly well! The
>  > crash Point is at featureSrvc.UpdateFeatures.
>  >                 <cfset deleteCmd = CreateObject("java",
>  > "org.osgeo.mapguide.MgDeleteFeatures").init(featureName, "ID >= 0")>
>  >                 <cfset commands = CreateObject("java",
>  > "org.osgeo.mapguide.MgFeatureCommandCollection")>
>  >                 <cfset commands.Add(deleteCmd)>
>  >                 <cfset featureSrvc.UpdateFeatures(dataSourceId, commands,
>  > false)>
>  >                 <cfset commands.delete()>
>  > _______________________________________________
>  >  mapguide-users mailing list
>  >  http://lists.osgeo.org/mailman/listinfo/mapguide-users
>  Zac Spitzer -
>  http://zacster.blogspot.com (My Blog)
>  +61 405 847 168
Zac Spitzer -
+61 405 847 168
