[mapguide-users] mapagent api docs
Jackie C. Ng jumpinjackie at gmail.com
Wed May 7 10:47:20 EDT 2008
There is no such documentation per se.
The mapagent is basically a http interface to the mapguide api. Basically
each method in the mapagent interface should have a corresponding method in
the mapguide api.
So an easy way to find out how to use a particular method in the mapagent,
look up the corresponding method in the mapguide api documentation (the
methods are conveniently grouped by service for this purpose). It's method
signatures should tell you what parameters are required to invoke a
particular method via the mapagent interface.
- Jackie
juan dela cruz-2 wrote:
> hello all,
> does anybody know where i can find mapagent api documentation?
> thanks.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/mapagent-api-docs-tp17103280p17106194.html
