[mapguide-users] query question
David Nuell nuell at nicholsenvironmental.com
Wed May 7 16:06:05 EDT 2008
My query script is the exact same as the /phpviewersample/query/querymain.php
When I create a new command, I copy exactly what the sheboygan layout has as
a query command into my own layout.  The query comes up fine, but it never
shows any results regarless of what query I run (numbers or letters).  Any
help is greatly appreciated.
David Nuell wrote:
> Hi Listers -
> I am having some troubles with a query function and I hope that someone
> out there can help.
> - have a map built via MapGuide Studio
> - have created a new command called 'Query'
> - enter the exact same information into the settings of the query command
> as in the sheboygan data (i.e., invoke URL, URL to invoke, etc.)
> - save my web layout and open it in an AJAX viewer (and/or DWF viewer)
> - select the query command and it opens in the side window (right pane)
> - I can select a layer that is in my layers list along with everything
> else to query the data including the output property.
> As soon as I hit execute, nothing shows up.  I have the Sheboygan data
> installed and I tried to execute a query there too... but same result.
> Nothing shows up in the results panel.
> What am I missing?  I suppose it has something to do with the install
> since the sheboygan query does not work either.  Any ideas?
> Thanks (again).
View this message in context: http://www.nabble.com/query-question-tp16993307p17113535.html
