[mapguide-users] MapGuide Selection and UniqueID Determination
Crispin at 1Spatial
Crispin.Hoult at 1Spatial.com
Thu May 8 04:34:30 EDT 2008
Thanks Kenneth,
That helps if we have the definition of an "identity column". ie how does
FDO determine this? I assume (hope) it is not just having a FDO
"IsAutogenerated()" value as obviously a database could have a unique column
that is key but not from a sequence.
SHP and SDF generically get a "FeatId" autogenerated through the provider
but this is not the case for foreign database schemas.
Kenneth, GEOGRAF A/S wrote:
> To be able to select items the layer must be selectable (set in the
> MapDefinition).
> Secondly, the FeatureSource must have at least one identity column.
> If not, all features on the layer are selected.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Crispin @ 1Spatial skrev:
>> Hi,
>> Can someone explain how the magic of MapGuide selection works...
>> Of particular interest to me is a particular ArcSDE dataset that appears
>> fine in MapGuide but (despite correct settings in Studio) has a class of
>> points which when mapped as a layer do not 'select' in the map.
>> Using a seperate direct FDO connection I can see the class has no
>> columns/proprttydefinitions that are "IsAutogenerated()" - is this a
>> requirement for a layer to be selectable or is there another criteria?
>> Tooltips appear OK.
>> Crispin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MapGuide-Selection-and-UniqueID-Determination-tp17106209p17122431.html
