[mapguide-users] Fusion query()ing from any zoom level
Kimmo Kotajärvi
Kimmo.Kotajarvi at vianova.fi
Thu May 8 05:49:53 EDT 2008
I'm trying to use the javascript query function. Take this fictional example, executed from inside the task pane:
Var options = {};
Options.layers = 'roads_layer';
Options.filter = 'road_width > 5';
Parent.Fusion.getWidgetById('Map').query(options);
This works nicely when the "roads_layer" is actually visible, but not when the map is zoomed out far enough. What I finally want to achieve is: User clicks on an asp.net generated list of objects -> query and select -> zoom extents to selection.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080508/386307ec/attachment.html
