[mapguide-users] Fusion Selection Error | Symbols
Mike Adair
madair at dmsolutions.ca
Fri May 9 16:32:59 EDT 2008
Brian,
I think the Query fix was made after that, and the 1.0.5 release also
had an issue with status bar items being pushed left. I'm not sure of
the timing for 1.0.6 or MGOS 2.0.1, but if you are able to use SVN,
those are fixed in the 1.0 branch
(http://svn.osgeo.org/fusion/branches/fusion-1.0).
Mike
Berdel, Brian wrote:
> The one that came bundled with 2.0. I tried upgrading to 1.4 but
> everything in the status bar was pushed to the left. I was going to try
> 1.3.
> -Brian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
> Sent: Friday, May 09, 2008 3:42 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Fusion Selection Error | Symbols
> That error typically occurs after an AJAX call that returns invalid JSON
> - usually due to exceptions being thrown in a PHP script. The more
> recent versions of Fusion give a better error message (location,
> message and stack trace filled in). You can also see what the error
> message is in the Firebug console.
> Having said that, it's difficult to tell exactly which PHP is causing
> trouble, but trying to select something indicates it is in the Query.php
> script. There was a fix to Query.php not too long ago related to null
> property values. What version of fusion are you using?
> Mike
> Martin Morrison wrote:
>> We seem to be getting this error while making small changes to the
>> interface. We tried upgrading Fusion, it helped some, but it still
>> has issues. Maybe someone with more Fusion experience can chime in.
>> Martin
>> *From:* mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Berdel,
>> Brian
>> *Sent:* Friday, May 09, 2008 2:00 PM
>> *To:* MapGuide Users Mail List
>> *Subject:* [mapguide-users] Fusion Selection Error | Symbols
>> I am getting an ajax callback error when trying to select a point with
>> a custom symbol. Anyone else experiencing this?
>> Brian
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
