[mapguide-users] Difference between MG Open Source and
MG Enterprise2007 for layer point from coordinates Lat Lon
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sun May 11 07:32:47 EDT 2008
It is the exact same procedure for both Enterprise and OS.
They have different coordinate system providers (PROJ.4 vs. Mentor).
Could it be a coordinate system issue?
Can you try with XY-M or something similiar?
Regards, Kenneth Skovhede, GEOGRAF A/S
alba skrev:
> Hi all,
> I must to create a layer of point from database with coordinates Lat Lon
> I have execute:
> Create a datasource.
> Create a layer with the datasource.
> Create a map.
> Select the coordinate system.
> Specify the center coordinate manually.
> Add the layer.
> Press refresh.
> All this is true for Map Guide Open Source, but it not true for Map Guide
> Enterprise, Why?
> The layers of points in MG Enterprise are not visible, it can be the
> problem of System coordinates?
> Tanks Alba
