[mapguide-users] Fusion security?
Paul Spencer
pagameba at gmail.com
Tue May 13 20:08:34 EDT 2008
Right now, fusion uses the Anonymous user by default but will update
the server to use specific credentials if they are provided - I can't
specifically remember how to specify them but I do know that you can
pass in a session id that was previously created so you can have
something that logs a user in, creates a session and then launches the
fusion app with the session id. I also did something for Jason that
allowed a user to connect anonymously initially but then log in.
Hum, seems like this is something we need to put some thought into :)
Comments, discussion welcome
Paul
On 13-May-08, at 3:26 PM, Andrew DeMerchant wrote:
> I'm not getting a login prompt when I go to view my Fusion layouts.
> Is there some reason for that? Is there something that I need to do
> in order to get it to force a login?
> Andrew
> <logo.gif>
> Andrew DeMerchant
> Computer Technologist
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> GEMTEC Limited
> 191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
