[mapguide-users] MrSID not working with 2.0?
Dave Wilson dave.wilson at autodesk.com
Thu May 15 15:24:16 EDT 2008
Just something to eliminate but often people in their feature sources depending on the raster format are not ensuring a coordinate system is defined on the feature source. This is important and is required, it's possible this could cause some problems.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
Sent: Thursday, May 15, 2008 1:06 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MrSID not working with 2.0?
I am able to show MrSid files with MGOS 2.0, but from time to time I get
server crashes. The log files are indicating something went wrong with
stylization of the layer, but I could not find any pattern in the crashes.
Therefore I disabled the raster layers. Looking on the forum there are a lot
of people encountering similar problems with raster files.
Rock Beans wrote:
> That makes me cry a little. Well if I come up with anything I will post
> back. Any other info from the top dogs would be great!
> Thanks
> The Rock
> On Tue, May 13, 2008 at 1:54 PM, Andrew DeMerchant <
> andrew.demerchant at gemtec.ca> wrote:
>>  No luck here....I've had success with other formats though. I filed a
>> trac about my mrsid problem a month ago (or so).
>> Rock Beans wrote:
>> I followed the directions on the
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0 pages.
>> I
>> am not getting any to work. I have not tested any other formats yet. Has
>> anyone had luck with this or is there an update to the GDAL?
>> The Rock
>> mapguide-users mailing
>> listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
>>     *Andrew DeMerchant*
>>  *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> *GEMTEC Limited <http://www.gemtec.ca>
>> *191 Doak Road
>> Fredericton, NB, Canada
>>  E3C 2E6
>> mapguide-users mailing list
View this message in context: http://www.nabble.com/MrSID-not-working-with-2.0--tp17215741p17260246.html
