[mapguide-users] MrSID not working with 2.0?
Rock Beans rockbeans at gmail.com
Fri May 16 12:20:25 EDT 2008
I found out I had a trailing slash on the raster path within the feature
source settings. For example, "C:\rasterfiles\" so removing that trailing
slash allowed the cord system override to actually work along with the
preview. Very strange these where settings from 1.2 so something must have
changed. Word to the wise simple fix :-) Still getting some MapGuide Server
lockups but I have to make sure everything cord system wise in in line
before I can judge.
The Rock
On Fri, May 16, 2008 at 10:54 AM, Rock Beans <rockbeans at gmail.com> wrote:
> I did find the override cord system in studio not sure why I did not see it
> before. I will try this and report back.
> Thanks!
> The Rock
> On Fri, May 16, 2008 at 10:45 AM, Dave Wilson <dave.wilson at autodesk.com>
> wrote:
>>  Using MapGuide Studio and configuring Raster via an unmanaged connection
>> with the Autodesk provider there is the SupplementalSpatialContextInfo as
>> shown below in the feature source definition:
>>   <?xml version="1.0" encoding="utf-8" ?>
>> - <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>>   <Provider>Autodesk.Raster</Provider>
>> - <Parameter>
>>   <Name>DefaultRasterFileLocation</Name>
>> <Value>%MG_DATA_PATH_ALIAS[Cal_GBU_QA_Data]%Raster/SanFran-UTM27-10/jpg/</Value>
>>   </Parameter>
>> - <SupplementalSpatialContextInfo>
>>   <Name>Default</Name>
>> <CoordinateSystem>PROJCS["UTM27-10",GEOGCS["LL27",DATUM["NAD27",SPHEROID["CLRK66",6378206.400,294.97869821]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["false_easting",500000.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",-123.00000000000000],PARAMETER["scale_factor",0.9996],PARAMETER["latitude_of_origin",0.000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
>>   </SupplementalSpatialContextInfo>
>>   <ConfigurationDocument>config.xml</ConfigurationDocument>
>> </FeatureSource>
>> I'm not sure how the feature source looks for the Open Source provider,
>> but I'd be surprised there isn't an equivalent element available in the
>> schema.
>> Dave
>> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
>> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Rock Beans
>> *Sent:* Friday, May 16, 2008 9:32 AM
>> *To:* MapGuide Users Mail List
>> *Subject:* Re: [mapguide-users] MrSID not working with 2.0?
>> In a raster based feature source there is no where to override a cord
>> system so can you please explain?
>> On Thu, May 15, 2008 at 2:24 PM, Dave Wilson <dave.wilson at autodesk.com>
>> wrote:
>> Just something to eliminate but often people in their feature sources
>> depending on the raster format are not ensuring a coordinate system is
>> defined on the feature source. This is important and is required, it's
>> possible this could cause some problems.
>> Dave
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:
>> mapguide-users-bounces at lists.osgeo.org] On Behalf Of isca
>> Sent: Thursday, May 15, 2008 1:06 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: Re: [mapguide-users] MrSID not working with 2.0?
>> I am able to show MrSid files with MGOS 2.0, but from time to time I get
>> server crashes. The log files are indicating something went wrong with
>> stylization of the layer, but I could not find any pattern in the crashes.
>> Therefore I disabled the raster layers. Looking on the forum there are a
>> lot
>> of people encountering similar problems with raster files.
>> Rock Beans wrote:
>> > That makes me cry a little. Well if I come up with anything I will post
>> > back. Any other info from the top dogs would be great!
>> > Thanks
>> > The Rock
>> > On Tue, May 13, 2008 at 1:54 PM, Andrew DeMerchant <
>> > andrew.demerchant at gemtec.ca> wrote:
>> >>  No luck here....I've had success with other formats though. I filed a
>> >> trac about my mrsid problem a month ago (or so).
>> >> Rock Beans wrote:
>> >> I followed the directions on the
>> >> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0pages.
>> >> I
>> >> am not getting any to work. I have not tested any other formats yet.
>> Has
>> >> anyone had luck with this or is there an update to the GDAL?
>> >> The Rock
>> >> _______________________________________________
>> >> mapguide-users mailing
>> >> listmapguide-users at lists.osgeo.orghttp://
>> lists.osgeo.org/mailman/listinfo/mapguide-users
>> >>     *Andrew DeMerchant*
>> >>  *Computer Technologist*
>> >> ph.1-877-2GEMTEC x.163
>> >> fax 506-453-9470
>> >> *GEMTEC Limited <http://www.gemtec.ca>
>> >> *191 Doak Road
>> >> Fredericton, NB, Canada
>> >>  E3C 2E6
>> >> mapguide-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/MrSID-not-working-with-2.0--tp17215741p17260246.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080516/974b54de/attachment.html
