[mapguide-users] Please try your operation later as the resource was busy
Mark Pendergraft markp at meadgilman.com
Fri May 16 15:03:29 EDT 2008
I'm a little confused here.
You make it sound as if only one person can update the library resource (in
this case a .sdf file) at a time.  I thought that multiple people could
interact with the file making changes at the same time more like a database.
I get this error about every other time i try to add a feature to my feature
source.  There is a lot of code that could be suspect, i will try to isolate
the error this weekend and if it's not my code i will submit a trac ticket.
Bruce Dechant wrote:
> Mark,
> The error you see below is typically a result of the resource still being
> used by someone else. However, if a feature reader is not closed and you
> try to do something with the same resource (update) it can report that it
> is in use still and therefore busy.
> Since you are closing your feature reader I suspect the problem is most
> likely a defect if you are the only one that is using it.
> What provider is this happening with? Is this easily reproduced?
> If you could create a track ticket for this and include as much
> information as possible for someone to investigate the issue that would be
> great.
> Thanks,
> Bruce
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
> Pendergraft
> Sent: Friday, May 16, 2008 11:44 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Please try your operation later as the
> resource was busy
> I am getting this message too.  I am closing my feature reader and
> disposing
> of it.
> The problem happens when the user adds features to one of the feature
> sources named "Jobs".  We use our map primarily to track where we have
> worked, and users need to be able to add jobs to the map.  Sometimes it
> works, other times it harrasses me about the resource being busy.  I would
> have to use the library resource because the changes need to show up in
> everyones map.
> Am i missing something here?  is there a way to possibly check if the
> resource is busy and force it to not be?
> zspitzer wrote:
>> Are you closing your featureReader? show us some more code :)
>> Also, you probably want to be using session resources rather than
>> library resources
> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-tp16392736p17280519.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Please-try-your-operation-later-as-the-resource-was-busy-tp16392736p17282025.html
