[mapguide-users] New UpdateFeatures problem
Zac Spitzer zac.spitzer at gmail.com
Mon May 19 02:02:14 EDT 2008
Can you do a clean start of mapguide which isn't being used by other
users and then
run your code to reproduce the problem and then post the Mapguide
Server Access.log entries?
That will show the series of API calls being made.
That aside, posting some sample code which reproduces the issue is your best
chance of somebody spotting a problem or for the bug to be confirmed
Z
On Mon, May 19, 2008 at 3:44 PM, Klaus Lehtonen <kle at vianova.fi> wrote:
> I am using Oracle fdo provider.
> zspitzer wrote:
>> which fdo provider (database) are you using?
> View this message in context: http://www.nabble.com/New-UpdateFeatures-problem-tp17248351p17311673.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
