[mapguide-users] mgserver process hangs / memory usage
G.E.O.-Consulting / Hans Morschell moerschell at geo.co.at
Tue May 20 03:36:53 EDT 2008
hallo,
we are using MGOS in the following environment:
-          MGOS 2.0
-          IIS6 on MS Server2003
-          ASP application / .Net environment
-          Server with dual processor / 4 GB RAM
our application has one map, one layout, about 50 layers, some MRSID, some
TIFF and shape files, user can calculate a route, therefore we have 4
dynamic layers in session repository
The mgserver process occasionally crashes and monitoring the memory usage I
can see the following behaviour:
After starting the mgserver process the use of memory continously increases,
the pagefile size grows permanetly, and both of them do never decrease.
Error messages in mgserver logfiles:
-          out of memory, bad allocation
-          failed to stylize layer
-          no more fdo connections
-          unexpected exception
-          ressource busy
the error messages are not allways identical.
The mgserver process hangs completely, can not be restarted so I have to
restart the server.
Does anybody have a similar situation ?
I didn't change settings in serverconfig.ini, any hints, what to change
there ?
Why does the mgserver process not deallocate memory, may be there is
something wrong in my IIS6 configuration ?
Thanks for any help, Hans
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080520/1d310e9a/attachment.html
