[mapguide-users] New flexible layout
Jackie C. Ng
jumpinjackie at gmail.com
Tue May 20 08:18:15 EDT 2008
Are you trying to pass a fusion flexible layout into the basic ajax viewer?
Web Layouts and Flexible Layouts (aka. Application Definitions) are two
totally different things with two different XML schemas.
- Jackie
Eric123 wrote:
> Hi All,
> Anyone knows why it can't to work with flexible layout? It prompts the
> following msg:
> An exception occurred in the XML parser.
> An exception occurred in the XML parser. Exception occurred in method
> MgWebLayout.ParseWebLayoutDefinition at line 276 in file WebLayout.cpp
> Basic layout can be work fine! Why??
> Cheers,
> Eric
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/New-flexible-layout-tp17336795p17338972.html
