[mapguide-users] mgserver process hangs / memory usage
Jim O'Leary
jo at pat.ca
Tue May 20 14:13:59 EDT 2008
Can you share your batch file?
Thanks
xuzhengeology wrote:
> We meet the same problem in our project.
> The memory increases when we are using mgservices.we can find any api to
> release the memory.
> In the beginning, the memory is about 54Mb,it creashes when the memory
> goes to 220Mb.
> Now,we have to use a .bat file to restart the server before it goes to the
> dead line of the memory,before it gets to 200Mb.
> we restart the server in the midnight automatically.
> This is our tempory ways to solve this problem.
> by the way ,if u only pan or zoom the layer in tile mode.memory wonn't
> increase,only if u use mgservices to add or edit the
> information of the layer.
> If u use tiled map,tile the whole map before u publish it.the tile
> processing cause crash very quickly.
> hope can help.
> 2008-05-20
> xuzhengeology
> 发件人: G.E.O.-Consulting_/_Hans_Morschell
> 发送时间: 2008-05-20 15:57:17
> 收件人: MapGuide Users Mail List
> 抄送:
> 主题: [mapguide-users] mgserver process hangs / memory usage
> hallo,
> we are using MGOS in the following environment:
> - MGOS 2.0
> - IIS6 on MS Server2003
> - ASP application / .Net environment
> - Server with dual processor / 4 GB RAM
> our application has one map, one layout, about 50 layers, some MRSID, some
> TIFF and shape files, user can calculate a route, therefore we have 4
> dynamic layers in session repository
> The mgserver process occasionally crashes and monitoring the memory usage
> I can see the following behaviour:
> After starting the mgserver process the use of memory continously
> increases, the pagefile size grows permanetly, and both of them do never
> decrease.
> Error messages in mgserver logfiles:
> - out of memory, bad allocation
> - failed to stylize layer
> - no more fdo connections
> - unexpected exception
> - ressource busy
> the error messages are not allways identical.
> The mgserver process hangs completely, can not be restarted so I have to
> restart the server.
> Does anybody have a similar situation ?
> I didn’t change settings in serverconfig.ini, any hints, what to change
> there ?
> Why does the mgserver process not deallocate memory, may be there is
> something wrong in my IIS6 configuration ?
> Thanks for any help, Hans
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Jim O’Leary Bachelor of Technology
Technical Consultant
Pacific Alliance Technologies
TEL 604.676.6000 EXT 110 TOL 877.691.9171
FAX 604.682.0962
WEB http://www.pat.ca/ www.pat.ca
“A Member
of StarDyne Technologies”
http://www.stardynetech.com/ www.stardynetech.com
The information contained
in this message may be privileged and confidential and protected from
disclosure. If the reader of this message is not the intended recipient, or
an
employee or agent responsible for delivering this message to the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this message is strictly prohibited. If you have received this
message in error, please notify us immediately by replying to this message
and
deleting it from your system without making a copy. Internet
communications cannot be guaranteed to be secure or error-free as
information
could be intercepted, corrupted, lost, arrive late or contain viruses.
We
are not liable for the timely, proper or complete transmission of the
information contained in such communications. We are also not liable
for
the loss of confidentiality of information contained in such communications.
View this message in context: http://www.nabble.com/mgserver-process-hangs---memory-usage-tp17335201p17347019.html
