[mapguide-users] Update Line Feature Class
akram akram at gsg-eg.com
Wed May 21 11:40:31 EDT 2008
Thank You Very Much Kenneth  I got it.......
Kenneth Skovhede, GEOGRAF A/S writes:
> Hello Akram.
> What you do here, is essentially copy a map's xml definition. Your step 1
> is the same as calling resourceService.CopyResource(layerDefResId,
> layerDefId).
> I can't see where your "newLayer" variable comes from (the one you
> insert).
> If you already have a layer, it is much easier to include it in the map,
> but keep it invisible. Then turn it on when you want to display it. That
> would remove step 1 and 2.
> You only have to create a copy of the layer if you want to modify it for
> the current session. If you want the layer to display another feature
> source, you must update the xml in step 1.
> Step 3 looks OK.
> In step 4, I think you have used the id of the layerdefinition, rather
> than the id of the featuresource. I am not sure you can do that.
> If step 3 and 4 are completed, a refresh of the map should display your
> new feature.
> Perhaps the coordinates are misplaced, so the feature is inserted outside
> the map?
> If you have access to MapGuide Studio, you can preview your feature
> source, and see the actual data rows.
> With that, you can verify that there is an added row.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> akram skrev:
>> Hi Kenneth, Hi All,
>> I would like to create new Line (MgFeatureGeometricType.Curve) Layer ,
>> and create line feature in this new Layer , I worked with follwoing
>> steps:
>> 1.Take Layer Definition for Exsisting Line Layer and SetResource as
>> following
>> MgByteReader byteReader =
>> resourceService.GetResourceContent(layerDefResId); XmlDocument doc = new
>> XmlDocument(); String xmlLayerDef = byteReader.ToString();
>> doc.LoadXml(xmlLayerDef); String xmlString =
>> doc.DocumentElement.OuterXml; MgResourceIdentifier layerDefId = new
>> MgResourceIdentifier("Session:" + GetParameter(this.args, "SESSION") +
>> "//NewLayer.LayerDefinition"); resourceService.SetResource(layerDefId,
>> new MgByteReader(xmlString, "text/xml"), null);
>> 2. Insert New Layer
>> layers.Insert(layers.IndexOf(layer), newLayer);
>> 3.Create Line Geometry
>> MgLinearRing Line = geometryFactory.CreateLinearRing(coordinateColl);
>> MgGeometry Geom = geometryFactory.CreatePolygon(Line, null);
>> 4.Write Geometry and Update Featur Service
>> propertyValues.Add(new MgGeometryProperty("Geometry", byteReader1));
>> updateCommands.Add(new MgInsertFeatures(className, propertyValues));
>> MgFeatureService featureService =
>> (MgFeatureService)this.site.CreateService(MgServiceType.FeatureService);
>> featureService.UpdateFeatures(layerResId, updateCommands, false);
>> 5. Save map and refresh
>> after previouse steps No thing appear , No bugs , No Result , Only
>> NewLayer Created
>> Can you help me plz to update Exsisting Line Layer ?
>> Best Regards
>> Akram
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080521/34919d18/attachment.html
