AW: [mapguide-users] Loading dwf without Mapguide Studio
Andy Morsell amorsell at spatialgis.com
Wed May 21 11:59:10 EDT 2008
I agree that DWF is by far the better data type when trying to preserve the graphic fidelity of complex vector data, especially when representing things like floor plans with dimensions, symbols and labeling.  But, it lacks any real object intelligence, which is where SDF based data is much better.
When you load a DWF via Studio, it treats it as a "drawing" source.  Meaning, it just copies the DWF into the repository and adds the necessary information to the database.  There is no option to convert to feature data.  There is no DWF FDO provider, and I suspect that the reason for this is that the drawing service is already provided in the core of MapGuide Open Source.
It sounds like there might be some confusion around loading DWF versus DWG in Studio: when loading a DWG, you have the option to load it as drawing or feature data.  If as feature data, it converts to SDF.  If as drawing data, it converts to DWF.  I have found that publishing DWG to DWF from Autodesk Map and then loading the DWF files yields more flexible results in MapGuide.  If you do it that way, the DWG layer information is carried forward and you can then filter your MGOS layer based on the DWF layers.  If you do it in Studio, the resultant DWF is just one big blob.  One thing to watch when publishing from Map is to make sure all of your pen weights are set to 0.00. Otherwise you will get the defaults and your DWF layers will look bad when zoomed in in MGOS.
In one of my DWF data sources, if I use the DescribeDrawing mapagent operation, here is the result.  So, Studio is doing quite a bit when loading the DWF, but that doesn't mean that this could not be done from outside of Studio.
<dwf:Manifest version="6.0" objectId="nt1vld7L4E67Z6G3FXkVWA">
 <dwf:Interfaces>
<dwf:Interface objectId="715941D4-1AC2-4545-8185-BC40E053B551" name="ePlot" href="http://www.autodesk.com/viewers"/ <http://www.autodesk.com/viewers> >
</dwf:Interfaces>
 <dwf:Properties>
<dwf:Property name="DWFToolkitVersion" value="7.2.1.116"/>
</dwf:Properties>
 <dwf:Sections>
 <dwf:Section type="com.autodesk.dwf.ePlotGlobal" name="com.autodesk.dwf.ePlotGlobal">
<dwf:Source provider="AutoCAD" href="RHSD_ATC_F1_2-Model.dwf"/>
 <dwf:Toc>
<dwf:Resource role="AutoCAD Drawing Set Data" mime="application/x-dsd" href="com.autodesk.dwf.ePlotGlobal\oN1vld7L4E67Z6G3FXkVWA.dsd"/>
<dwf:Resource role="descriptor" mime="text/xml" href="com.autodesk.dwf.ePlotGlobal\descriptor.xml"/>
</dwf:Toc>
</dwf:Section>
 <dwf:Section type="com.autodesk.dwf.ePlot" name="com.autodesk.dwf.ePlot_n91vld7L4E67Z6G3FXkVWA" title="RHSD_ATC_F1_2-Model">
<dwf:Source provider="AutoCAD" href="DWF204Temp.dwf"/>
 <dwf:Toc>
<dwf:Resource role="2d streaming graphics" mime="application/x-w2d" href="com.autodesk.dwf.ePlot_n91vld7L4E67Z6G3FXkVWA\od1vld7L4E67Z6G3FXkVWA.w2d"/>
<dwf:Resource role="AutoCAD Viewport Data" mime="application/x-dwg-state" href="com.autodesk.dwf.ePlot_n91vld7L4E67Z6G3FXkVWA\ot1vld7L4E67Z6G3FXkVWA.pia"/>
<dwf:Resource role="descriptor" mime="text/xml" href="com.autodesk.dwf.ePlot_n91vld7L4E67Z6G3FXkVWA\descriptor.xml"/>
<dwf:Resource role="thumbnail" mime="image/png" href="com.autodesk.dwf.ePlot_n91vld7L4E67Z6G3FXkVWA\o91vld7L4E67Z6G3FXkVWA.png"/>
</dwf:Toc>
</dwf:Section>
</dwf:Sections>
</dwf:Manifest>
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stephan HOLLAUS
Sent: Wednesday, May 21, 2008 4:40 AM
To: MapGuide Users Mail List
Subject: AW: AW: [mapguide-users] Loading dwf without Mapguide Studio
DWF drawing Source
mfg Stephan Hollaus
Ingenieur Studio Hollaus
Tel.:   +43 664 3387158
Fax.:  +43 664 77 3387159
www: http://www.hollaus.at <http://www.hollaus.at/>
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
  _____
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Kenneth Skovhede, GEOGRAF A/S
Gesendet: Mittwoch, 21. Mai 2008 13:16
An: MapGuide Users Mail List
Betreff: Re: AW: [mapguide-users] Loading dwf without Mapguide Studio
Interresting.
What is the provider type of the DWF feature source?
Regards, Kenneth Skovhede, GEOGRAF A/S
Stephan HOLLAUS skrev:
i thought so too, but then I found the dwf File in the Folder "C:\Programme\MapGuideOpenSource2.0\Server\Repositories\Library\DataFiles\b70eab7a-ffff-ffff-8000-000c29c577cf" on der Mapguideserver. I found no matching sdf data and when the dwf is removed, mapguide doesn't display the data anymore, so that I believe there is a direct connection. The ohter thing is, that we use dwf because the very complex data(linetypes, Symbols..) and I can't believe, that this data is converted to sdf
mfg Stephan Hollaus
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
  _____
Gesendet: Mittwoch, 21. Mai 2008 12:05
Betreff: Re: [mapguide-users] Loading dwf without Mapguide Studio
Not that I know of.
There are no FDO providers capable of displaying DWF files:
http://fdo.osgeo.org/OSProviderOverviews.html
I belive Studio extracts the data from the DWF, and inserts it as SDF data in the server (but I have not tried it).
There exists a DWF toolkit, so you may do this manually:
http://usa.autodesk.com/adsk/servlet/index?id=823771 <http://usa.autodesk.com/adsk/servlet/index?id=823771&siteID=123112> &siteID=123112
I'm guessing it will take some time to get it all to work.
If you can live with Studio only being avalible on the windows platform, it is
possible to call Studio via. .Net and perform the loads without manual intervention.
Hi
Is there a way to load dwf Files without Mapguide Studio?
thx
mfg Stephan Hollaus
Brandströmgasse 10
3100 St. Pölten
V55BCPWP
  _____
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
  _____
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080521/10fae2bb/attachment.html
