[mapguide-users] mgserver process hangs / memory usage
Rahul
unicorn_admirer at yahoo.com
Wed May 21 23:17:29 EDT 2008
Hi Jim,
Thanks for sharing your Python program but can it work on windows server 2003.
Thks
Max
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Wednesday, May 21, 2008 10:20:09 PM
Subject: Re: [mapguide-users] mgserver process hangs / memory usage
The attached Python program uses two command line utilities that are
available with XP Pro, TASKLIST and TASKKILL.
TASKLIST returns a string containing memory usage for each process. The
Python program parses out the memory usage for mgserver.exe. TASKKILL kills
the mgserver.exe process. The Python program tests if the memory usage for
mgserver.exe is greater than a certain limit and kills the process if it is,
and then restarts the mgserver.exe process.
This doesn't help the hapless user who suddenly finds that the map doesn't
work, but at least the map comes back after about 10 seconds.
Also we have found that, as Andy indicated earlier in this thread, the
newly-released MGOS 2.0.1 does a better job managing memory.
max_samart wrote:
> Hi,
> I am using the following code and using the windows scheduler to
> schedule the batch file.
> echo MapGuide Scheduler Task Starting
> taskkill /F /FI "SERVICES eq MapGuideServer1.2"
> net stop MapGuideServer1.2
> net start MapGuideServer1.2
> echo MapGuide Scheduler Task Completed
> Buti am getting the System Error 109 which is the "The Pipe has been
> ended", while executing net stop MapGuideServer1.2 line , kindly refer to
> the attached screen shot.
> Thks
> Max !
> From: nclayton <nclayton at gmail.com>
> Sent: Wednesday, May 21, 2008 2:58:50 AM
> I'm using the batch file apporach as well. I have it scheduled to run
> every 6
> hours to clear out the memory used.
> Here is the batch file I use:
> taskkill /F /FI "SERVICES eq MapGuideServer2.0"
> net stop MapGuideServer2.0
> net start MapGuideServer2.0
> http://www.nabble.com/mgserver-process-hangs---memory-usage-tp17335201p17349393.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/file/p17364311/monitorMapGuide.py monitorMapGuide.py
Jim O’Leary Bachelor of Technology
Technical Consultant
Pacific Alliance Technologies
TEL 604.676.6000 EXT 110 TOL 877.691.9171
FAX 604.682.0962
WEB http://www.pat.ca/ www.pat.ca
“A Member
of StarDyne Technologies”
http://www.stardynetech.com/ www.stardynetech.com
The information contained
in this message may be privileged and confidential and protected from
disclosure. If the reader of this message is not the intended recipient, or
an
employee or agent responsible for delivering this message to the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this message is strictly prohibited. If you have received this
message in error, please notify us immediately by replying to this message
and
deleting it from your system without making a copy. Internet
communications cannot be guaranteed to be secure or error-free as
information
could be intercepted, corrupted, lost, arrive late or contain viruses.
We
are not liable for the timely, proper or complete transmission of the
information contained in such communications. We are also not liable
for
the loss of confidentiality of information contained in such communications.
View this message in context: http://www.nabble.com/mgserver-process-hangs---memory-usage-tp17335201p17364311.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080521/d6d26884/attachment.html
