[mapguide-users] Use a template, Fusion, can't chance the map
Paul Spencer
pagameba at gmail.com
Thu May 22 09:46:26 EDT 2008
Romain,
are you using Studio to launch your fusion application? If yes, then
it uses an ApplicationDefinition stored in the mapguide repository and
changing the file on disk will have no effect so you will need to
change the map using Studio.
To use the ApplicationDefinition file on disk, you can go directly to
the template in your web browser with no extra parameters:
http://localhost:8008/mapguide/fusion/templates/mapguide/aqua/
Cheers
Paul
On 22-May-08, at 9:39 AM, Romain Quellec wrote:
> Hello,
> I use a template in WebServerExtensions\www\fusion\templates\mapguide
> \aqua
> I change the ApplicationDefinition.xml line 15,
> <ResourceId>Library://QSMS/Cartes/Cadriag.MapDefinition</ResourceId>
> but I have the Sheboygan map.
> Solutions?
> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
