[mapguide-users] [MapguideOS] Create layer filter
Jérémie Formica jeremie.formica at gmail.com
Fri May 23 03:39:30 EDT 2008
Hello,
I would like to select data from one layer by applying a filter.I have tried
the following code:
 $mgSessionId = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST['SESSION']:
$_GET['SESSION'];
 MgInitializeWebTier ($configFilePath);
 $userInfo = new MgUserInformation($mgSessionId);
 $siteConnection = new MgSiteConnection();
 $siteConnection->Open($userInfo);
 $resourceService =
$siteConnection->CreateService(MgServiceType::ResourceService);
 $featureService =
$siteConnection->CreateService(MgServiceType::FeatureService);
 $map = new MgMap();
 $map->Open($resourceService, 'Sheboygan');
 $layer = GetLayerByName($map, 'Parcels');
 $queryOptions = new MgFeatureQueryOptions();
 $queryOptions->SetFilter("RTYPE = 'RES'");
 $featureReader = $layer->SelectFeatures($queryOptions);
When I execute this code, the map post all Parcels but not the parcels with
"RTYPE = 'RES'").I want to get the same result that I get when applying a
filter in mapstudio.
Thanks
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080523/dfb2ef88/attachment.html
