[mapguide-users] King FDO and Table with 2 primary key
Haris Kurtagic
haris at sl-king.com
Mon May 26 15:34:28 EDT 2008
Ok thanks, you could also try to just read data ( no copy ) but I think
result would be same.
It sounds like provider problem, Simon will test it tomorrow and get
back to you.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ary sucaya
Sent: Monday, May 26, 2008 9:23 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] King FDO and Table with 2 primary key
Yes, i have primary key with 2 columns. I tried to copy oracle table
into SHP through FDO2FDO, and it said FDO class 'MY_TABLE' has more than
one identity property; only one identity property is supported.
Ary Sucaya
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Monday, May 26, 2008 9:18:07 PM
Subject: RE: [mapguide-users] King FDO and Table with 2 primary key
I guess you have primary key with 2 columns?
We will check provider itself and post findings.
In such cases , I would suggest to try to read table with Fdo2Fdo in
some cases that can be good indication where the problem is.
Haris
Sent: Monday, May 26, 2008 6:08 PM
To: Mapguide User
Subject: [mapguide-users] King FDO and Table with 2 primary key
Hii group,
I have an oracle table with 2 primary key. Everytime i select an object
from this table in MapGuide, MgServer will crash and need to restart. Is
there any workaround for this problem?
I'm using MGOS 1.2 and SL-King Oracle 0.7.3
Thank U
Ary Sucaya
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080526/fa9b067b/attachment.html
