[mapguide-users] MG - Authoring Map with Mapstudio
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue May 27 04:29:05 EDT 2008
Hi Katia.
For future posts, you should not attach files, because it is sent to
MANY people, and strains the mailserver.
If there is a need to attach a file, you can create a ticket for the
problem here:
http://trac.osgeo.org/mapguide/newticket
(You must be logged in, with an OSGeo userid:
http://www.osgeo.org/osgeo_userid/)
You can then attached the files to the ticket, and mail the list if you
want a quick answer.
I have loaded the data, but I don't have the SHP files, so I can't see
any data either.
I did notice that your layers have no style information.
On your layers, you must add a scale range. (Click the ruler icon).
Inside each scale range, you must add a display for either point, line
and/or area.
For each point/line/area, you must add at least one condition (Click the
document icon).
For each condition, you must decide if you want to show the features
and/or label them.
Finally, you must select the display style (color, patter, etc) for the
geometry and/or labels.
It is a lot of steps, and not at all intuitive. I am working on a much
improved editor for the next release.
Regards, Kenneth Skovhede, GEOGRAF A/S
katia.goes at katiagoes.com skrev:
> Friends.
> I´m trying to publish a map using Mapstudio, but I don´t know what is
> happing, because the geometry is not being shown in the main window.
> All layers that was created is enable, but not shown.
> I´m send in the file DuasBarras.mgp to tests.
> thanks a lot.
> Kátia Góes
> Especialista em SIG e Analista Ambiental
> www.katiagoes.com / 21-8308-0325
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080527/5acb3fbf/attachment.html
