[mapguide-users] King FDO and Table with 2 primary key
ary sucaya
ary.sucaya at yahoo.com
Tue May 27 06:41:09 EDT 2008
Hii Simon,
Maybe you can help me to understand this message from FDO2FDO:
FDO class 'MY_TABLE' has more than one identity property; only one identity property is supported.
What does it mean?
Regard,
Ary Sucaya
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Tuesday, May 27, 2008 12:29:14 PM
Subject: Re: [mapguide-users] King FDO and Table with 2 primary key
Hi!
I tested provider on table with primary key from 2 columns.
I tested MgServer 1.2 (provider version 0.7.3) and MgServer 2.0 but
i couldn't repeat problem (server crash).
Simon
ary sucaya wrote:
I don't get any error when i read it from fdo2fdo. Well, i hope this problem will be fixed soon :)
Ary Sucaya
Sent: Monday, May 26, 2008 9:34:28 PM
Subject: RE: [mapguide-users] King FDO and Table with 2 primary key
Ok thanks, you could also try to just read data ( no copy ) but I think result would be same.
It sounds like provider problem, Simon will test it tomorrow and get back to you.
Haris
From:mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ary sucaya
Sent: Monday, May 26, 2008 9:23 PM
Yes, i have primary key with 2 columns. I tried to copy oracle table into SHP through FDO2FDO, and it said FDO class 'MY_TABLE' has more than one identity property; only one identity property is supported.
Ary Sucaya
Sent: Monday, May 26, 2008 9:18:07 PM
I guess you have primary key with 2 columns?
We will check provider itself and post findings.
In such cases , I would suggest to try to read table with Fdo2Fdo in some cases that can be good indication where the problem is.
Haris
Sent: Monday, May 26, 2008 6:08 PM
To: Mapguide User
Subject: [mapguide-users] King FDO and Table with 2 primary key
Hii group,
I have an oracle table with 2 primary key. Everytime i select an object from this table in MapGuide, MgServer will crash and need to restart. Is there any workaround for this problem?
I'm using MGOS 1.2 and SL-King Oracle 0.7.3
Thank U
Ary Sucaya
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080527/81bb5758/attachment.html
