[mapguide-users] Dynamic Query Task Fails in MGOS 2.0.1
Don C. MacGregor
sir_sunkee at yahoo.ca
Thu May 29 18:40:37 EDT 2008
Thanks Max!!
I'll be using your code very soon :)
max_samart wrote:
> Hi All,
> Finally i able to manage to get going with Dynamic query task ,
> previously i did some online backup repositries as well as restore and all
> from MGOS 1.2 and was unable to select features using dynamic query ,but
> once i removed all the previous versions and installed the MGOS2.0.1 with
> some modifications in the query.php code as per my previous mail , i able
> to get going with my Windows Server2003+Php+Apache .
> Don give a try !!
> Cheers
> Max !!
> ----- Original Message ----
> From: Rahul <unicorn_admirer at yahoo.com>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Thursday, May 29, 2008 10:05:39 AM
> Subject: Re: [mapguide-users] Dynamic Query Task Fails in MGOS 2.0.1
> Hi Don,
> Regarding the Dynamic query Task you can change the
> query.php file in the D:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\phpviewersample\query\classes
> as there is some change due to the RFC35 and have to use -->
> MgCoordinateSystemFactory::GetTransform should be used instead of the
> deleted MgCoordinateSystemTransform constructor,
> So your code in the Function Execute will be --
> function Execute()
> $result = array();
> $resourceService =
> $this->site->CreateService(MgServiceType::ResourceService);
> $map = new MgMap();
> $map->Open($resourceService, $this->args['MAPNAME']);
> $layer = $map->GetLayers()->GetItem($this->args['LAYERNAME']);
> $featureService =
> $this->site->CreateService(MgServiceType::FeatureService);
> $resId = new MgResourceIdentifier($layer->GetFeatureSourceId());
> $featureClass = $layer->GetFeatureClassName();
> $featureGeometry = $layer->GetFeatureGeometryName();
> // Initialize the coordinate system transform
> $schemaAndClass = explode(":", $featureClass);
> $classDef = $featureService->GetClassDefinition($resId,
> $schemaAndClass[0], $schemaAndClass[1]);
> $geomProp = $classDef->GetProperties()->GetItem($featureGeometry);
> $spatialContext = $geomProp->GetSpatialContextAssociation();
> $csTransform = null;
> $csInverseTransform = null;
> $coordSysFactory = new MgCoordinateSystemFactory();
> $scReader = $featureService->GetSpatialContexts($resId, false);
> while ($scReader->ReadNext() && $csTransform == null)
> if ($scReader->GetName() == $spatialContext)
> $source =
> $coordSysFactory->Create($scReader->GetCoordinateSystemWkt());
> $target = $coordSysFactory->Create($map->GetMapSRS());
> $csTransform=$coordSysFactory->GetTransform($source, $target);
> $csInverseTransform=$coordSysFactory->GetTransform($target, $source);
> //$csTransform = new MgCoordinateSystemTransform($source, $target);
> //$csInverseTransform = new MgCoordinateSystemTransform($target,
> $source);
> This allow me to query and get the results but the stranged thing is
> happening that in one machine with (Windows XP+Apache+PHP) , I can query
> and select the results while in the other machine with
> Windows2003+Apache+Php, I can query but unable to select the features and
> use to get the error in the apache log file.
> Uncaught exception 'mgobjectnotfoundexception' in Unknown on line 0,
> referer:
> http://10.0.x.xx:8008/mapguide/phpviewersample/query/querymain.php
> Anyway Don you can give a try and i hope it will work for you if u r using
> windows XP +Apache+Php..
> Max!!
> From: Don C. MacGregor <sir_sunkee at yahoo.ca>
> To: mapguide-users at lists.osgeo.org
> Sent: Wednesday, May 28, 2008 9:08:52 PM
> Hi Max,
> I was too busy to research so I restored my MGOS 1.2 installation.
> max_samart wrote:
>> Hi All,
>> Finally I able to manage toperform search and get results using
>> the phpviewersample Query Task after changing few lines of codes from the
>> original one, but once i use the Select Button ,it doesn't use to select
>> feature and in the Apache Error.log file use to give the following error.
>> [Wed May 28 16:45:06 2008] [error] [client 10.0.x.xx] PHP Fatal error:
>> referer:
>> Can anybody tell me how to move forward or can give any kind of idea for
>> the possible cause of error.Hey Don have you got going with your custom
>> scripts in MGOS2.0.1 ,which was previously working with MGOS1.2.
>> Thks
>> Max !!
>> Sent: Tuesday, May 27, 2008 10:23:57 AM
>> Subject: [mapguide-users] Dynamic Query Task Fails in MGOS 2.0.1
>> Hi All,
>> I downloaded theMGOS 2.0.1 and tried with the sample
>> data-Shebogyan.mgp with the supplied phpviewersample for MGOS2.0.1 ,but
>> I unable to perform the query task on the sample data.I am using Win2K3,
>> Apache and PHP. Can anybody confirm about this or its just happening on
>> my
>> setup or i am missing something/configured something wrong.
>> Thks
>> Max
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Dynamic-Query-Task-Fails-in-MGOS-2.0.1-tp17482346p17513475.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Dynamic-Query-Task-Fails-in-MGOS-2.0.1-tp17482346p17547644.html
