[ZS2] Re: [mapguide-users] Automatic refresh map in web
	application
    Kenneth Skovhede, GEOGRAF A/S
    ks at geograf.dk
    Sat Nov  1 07:13:37 EDT 2008
That depends on your setup and requirements.
I would suggest that you place it in an outer html page.
If you look at the setup outlined on page 19 in the developers guide:
http://mapguide.osgeo.org/2.0/documentation.html
I would recommend using either "your banner" or "your frameset" to host
the code.
If you put it in the ajaxmappane, you have to use:
window.setInterval('Refresh()', 30000);
Because you are already in the mapframe when performing the call.
Regards, Kenneth Skovhede, GEOGRAF A/S
anakando skrev:
> hi Kenneth..where should i put that script? i tried to put into
> ajaxmappane.temp but not working.Thanx in advanced.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Do you mean something like?:
>> window.setInterval('GetMapFrame().Refresh()', 30000);
>> Grace Chai skrev:
>>> Hi,
>>> Does anyone has any idea about how to automatic refresh the map in the
>>> mapguide web application without pressing any button ?
>>> Thx for the idea suggested.
>>> regards,
>>> Grace
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081101/d04dcfc8/attachment.html
