SV: [mapguide-users] FW: [fusion-users] Fusion 1.1.0 Released
Måns Beckman mans.beckman at manandmachine.se
Mon Nov 3 05:34:48 EST 2008
I tried it out with MGE2009 SP1 and got some trouble with translations. Legend, selection and taskpane just get the variable names instead of the correct heading no matter what langue I select. Does anyone else got the same problem?
/Måns
-----Ursprungligt meddelande-----
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Jason Birch
Skickat: den 31 oktober 2008 22:17
Till: MapGuide Users Mail List
Ämne: [mapguide-users] FW: [fusion-users] Fusion 1.1.0 Released
In case you missed it, Fusion 1.1 has been released.
This should be a drop-in replacement to MGOS 2.0.2, and is faster and
more reliable than the bundled version.
It no longer requires users to modify their schemas to deal with the
localization change in OpenLayers; a convenience function was added to
Fusion that essentially does this for you.
If you are going to use this with MapGuide, you will have to:
- rename your existing Fusion directory to something like fusion_old
- install the new version of fusion
- copy the MapGuide-specific templates from the old directory
(fusion_old/templates/mapguide/*) to the new
- copy your fusion config file from the old directory into the new
(fusion_old/config.json) to the new
I _think_ that's it.  I'm working from SVN rather than the packaged
version, so post here or on the fusion-users mailing list if you run
into any problems.
Jason
-----Original Message-----
Sent: Friday, October 31, 2008 12:35
Subject: [fusion-users] Fusion 1.1.0 Released
The Fusion development team would like to announce the release of Fusion
1.1.0.
Fusion is a web-mapping application development framework for MapGuide
OS
and MapServer built primarily in JavaScript. It allows non-spatial web
developers to build rich mapping applications quickly and easily. Using
widgets, developers are able to add, remove, or modify functionality
using
standard-compliant HTML and CSS. Fusion does not require any proprietary
browser plug-ins and works in all the major browsers on Windows, Mac,
and
Linux.
This version addresses 60+ feature enhancements and bugs as identified
by
the release notes:
http://trac.osgeo.org/fusion/wiki/Releases/1.1.0/Notes.
Download:
http://trac.osgeo.org/fusion/wiki/GetIt
For general inquiries please subscribe to the fusion-users mailing list:
http://lists.osgeo.org/mailman/listinfo/fusion-users
For developer-related inquiries please subscribe to the fusion-dev
mailing
list:
http://lists.osgeo.org/mailman/listinfo/fusion-dev
Bugs, feature requests, and general task-related discussions can be
reported
using the Fusion Trac instance.  When filing tickets please include
detailed
information so the developers can quickly understand your request and,
in
the case of bugs, duplicate the behaviour.
Best regards,
Fusion Development Team
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
