[mapguide-users] Embed Fusion Layout in html or .aspx page
Dave Wilson
dave.wilson at autodesk.com
Mon Nov 3 19:26:53 EST 2008
Forget that. I figured it out. Each template even in MGE has an index.html file calling the Sheboygan samples. I will work with that and see what I discover.
Thanks for pointing me in the right direction.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, November 03, 2008 5:22 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Embed Fusion Layout in html or .aspx page
Unfortunately I'm not running an MGOS site. I'm working with an MGE site so I don't have that subdirectory. Where can I get a zip of that without a full download or install of the webserver?
Thanks,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
Sent: Monday, November 03, 2008 2:13 PM
Does this sample work for you?
C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\templates\mapguide\standard
Index.html?
The Fusion Layout is basically the ApplicationDefinition.XML file and that is called by the html or aspx page in the directory.
If you are using a template you can edit the template files as well.
Brian
Sent: Monday, November 03, 2008 12:19 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Embed Fusion Layout in html or .aspx page
Is there anything special that needs to be done to allow a fusion layout to be embedded in an html or aspx page? The layout loads, but commands like select within and things always generate a
'Fusion' is null or not an object error.
I'm guessing it has to be a scope problem or frame reference type of issue. With the Net consoles enabled in firebug the failure occurs in the fusion/Mapguide/php/Selection.php script
var map = GetParent().Fusion.getMapByName(mapName);
Any ideas?
Thanks,
Dave
Dave Wilson
GBU CRT, Calgary
Autodesk Canada Inc
Ph: 403.538.3069
Fax: 403.264.1442
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081103/35902a6e/attachment.html
