[mapguide-users] Search accross multiple layers
Dave Wilson dave.wilson at autodesk.com
Tue Nov 4 10:40:17 EST 2008
I think you are going to have to write code to loop through a list of layers selected by the user and query each to get results building a query against each independently. This would be a combination of the Select Within code UI and the Address Search to provide the input and select the layers.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jamo181
Sent: Monday, November 03, 2008 6:58 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Search accross multiple layers
Hi I'm trying to use the searchprompt.aspx and search.aspx to create a new
search that will be able to allow the user to search across more than 1
field and more than 1 layer...
I have been able to search more than 1 field so far, however I'm unsure on
how to search more than 1 layer.
These layers will have common properties, ( all cadastre, all have lot on
plan etc)
I'm stuck at this point.
            String featureClassName = layer.GetFeatureClassName();
            MgResourceIdentifier srcId = new
MgResourceIdentifier(layer.GetFeatureSourceId());
            MgFeatureReader features = featureSrvc.SelectFeatures(srcId,
featureClassName, opts);
My first attempt would be to try and add more features to the feature reader
...? is this possible?
Or can someone point me in the right direction to learn how to create a
filter across multiple layers...?
Cheers
Adam
View this message in context: http://www.nabble.com/Search-accross-multiple-layers-tp20314877p20314877.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
