[mapguide-users] DotNet Viewer Sample application Problem
padmini godavarthi
godavarthi.padmini at gmail.com
Thu Nov 6 04:59:39 EST 2008
Iam Using Mapguide opensource 2.0.while running the dotnetviewersample
application we got an error that
1. Failed to map the path '/utilityfunctions.aspx'.
2. Validation (): Element 'html' occurs too few times.
iam using .net 2.0 with IIS
I have another problem also
after loading the package successfulluy while running the mapviewer ajax
application (given pdf )
http://localhost/mapguide/mapviewerajax/ajaxviewer.aspx/?WEBLAYOUT=Library%3a%2f%2fSamples%2f%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout
(i can say-layouts are all in correct path)
i got an error that
Server Error in '/mapguide' Application.
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its
dependencies) could have been removed, had its name changed, or is
temporarily unavailable. Please review the following URL and make sure that
it is spelled correctly.
Requested URL: /mapguide/dotnetviewersample/overview/overviewmain.aspx
Version Information: Microsoft .NET Framework Version:2.0.50727.832; ASP.NET
If anybody Know about this error plz help me
View this message in context: http://www.nabble.com/DotNet-Viewer-Sample-application-Problem-tp20358142p20358142.html
