[mapguide-users] Tracking vehicles, Displaying positions
Warren Medernach wmedernach at rand.com
Fri Nov 7 10:09:59 EST 2008
Yes, AutoCAD Map can import, export, and direct connect to SHP files.
A DXF is an Autodesk 'exchange format' and can also be read by AutoCAD
Map.
Yes, MapGuide can import and connect (external) to SHP files.
Hope this helps
Warren M
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Carmelo
Saffioti
Sent: Friday, November 07, 2008 9:12 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Tracking vehicles, Displaying positions
I don't have Autocad Map, but I'm planning to get the trial version to
do this job faster...
For exporting shape files do I need Autocad Map? Do MapGuide import
shape files? Some people told me that it can import DXF files...
	----- Original Message -----
	From: Berdel, Brian <mailto:brian.berdel at mcmtrans.com>
<mailto:mapguide-users at lists.osgeo.org>
	Sent: Friday, November 07, 2008 3:20 PM
	Subject: RE: [mapguide-users] Tracking vehicles, Displaying
positions
	Do you have Autocad map or land desktop?  If so you can export
to shape files.
	Brian
Saffioti
	Sent: Friday, November 07, 2008 4:22 AM
positions
	Hi Kenneth,
	thank you for your suggestion. I stored NMEA data with separate
columns for lat/lon...
	Regarding DWG import, I'd like open source solutions, do you
know anything about? DWG is proprietary, but if I export to DXF is there
any open source solution to import it into MapGuide?
	Cheers
	Carmelo
<mailto:ks at geograf.dk>
		Sent: Thursday, November 06, 2008 9:17 AM
		Hi Carmelo.
		If you pre-process your NMEA data and extract lat/lon
values into columns, you
		can use the ODBC provider and make points of the
columns.
		I would suggest some kind of service that regularly does
this on the MySql server.
		Since DWG is a proprietary format, you can't do it with
open source tools.
		Autodesk MapGuide Studio can import a DWG for you, and
it is fairly inexpensive.
		Regards, Kenneth Skovhede, GEOGRAF A/S
		Carmelo Saffioti skrev:
		Hi everybody,
		I need to develop a system for tracking and displaying
vehicles
		positions. I'm storing NMEA gps sentences into a MySql
DB. Now I'd
		like to display these positions on a map. How can I do?
I'm new to
		this, can you give me any suggestion?
		I have to create the map too, because this zone is not
mapped. Is it
		possible to create a map from a DWG cad file?
		I hope you can help me
		Cheers
		Carmelo
		mapguide-users mailing list
		http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081107/dfdd7882/attachment.html
