[ZS2] [mapguide-users] Error on Connection *.mdb
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Nov 10 03:20:23 EST 2008
If you click "Test connection" on the FeatureSource, do you get any errors?
Regards, Kenneth Skovhede, GEOGRAF A/S
ajid1980 skrev:
> Hai .. my step connect mdb is like :
> You need to do this:
> 1. Click "New"
> 2. Select "Dataconnection"
> 3. Select "OSGeo FDO provider for ODBC"
> 4. Select "File on the server (Unmanaged)"
> 5. Type the path to the .mdb file
> 6. Confirm the connection string
> 7. Click "Configure columns"
> 8. Select the table to the left.
> 9. Check the "Geometry" box
> 10. Select the x and y columns
> 11. Click OK
> 12. Click the "Save" button.
> You now have a FeatureSource you can use in a layer, and it can display
> your points.
> To theme the layer do this:
> 1. Click "New"
> 2. Select "Layer"
> 3. Click the "..." button and browse to your FeatureSource
> 4. Uncheck "Display lines" and "Display areas"
> 5. Click the green "+" next to the word "Rule"
> 6. Enter a filter, eg: 'Status' LIKE "Avalible"
> 7. Double click the point and select how an "Avalible" item should look.
> 8. Repeat for any additional states like "Busy", "Broken", etc.
> Since the data is read from the database, you can update the database
> using regular sql, outside of MapGuide.
> If you change the "Status" field, the point will also change apperance
> (eg. color) according to the rules.
> The Error is :-
> 1) i cannot setting initial mapvier, error "failed to get layer extend
> 2) on browser .. no display point..
> Confius /:- setting lat/long on "configure colums" X,Y,Z
> Thanx
