[mapguide-users] Maps not visible in MgOS 2.0.2
Andy Morsell
amorsell at spatialgis.com
Tue Nov 11 01:09:06 EST 2008
Do the sample maps from the Sheboygan sample dataset work? If not, then it
looks like an IIS and MGOS installation and configuration issue.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of MacNair
Sent: Monday, November 10, 2008 9:50 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Maps not visible in MgOS 2.0.2
Am unable to view maps (authored in Mge2009 Studio) via our Mapguide
application with Maguide Open source 2.0.2 Server. The viewer gives a blank.
However, we are able to view the maps through our application with Mge 2009
server though.
These maps have the following data authored...
1. Themed layers
2. Feature joins between SDF and SQL server table.
I was able to view these maps previously (authored in Mge2008 Studio) with
using Mapguide open source 1.2. I recently installed Mapguide open source
2.0.2 to try the maps authored in Mge2009. The open sources Windows
installer didn't create the virtual directory at the end of the
installation. I did it manually and configured the application in IIS. The
installation was done on Win2003 SP2.
Suggestions are welcome. Issues with application configuratin in IIS which I
did manually?
Thanks and Regards!
View this message in context:
http://n2.nabble.com/Maps-not-visible-in-MgOS-2.0.2-tp1483925p1483925.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
