[mapguide-users] How to publish map as WMS
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Nov 11 05:51:29 EST 2008
In MapGuide, you publish a layer, not a map (unfortunate IMO).
You simply right click the layer, and under properties there is a
"Service" or "WMS" entry.
There you must enable the layer as a WMS layer, and set some properties.
After that, you should be able to pass the regular MapGuide URL to an
WMS enabled service:
http://server/mapguide
(And WMS must not be deactivated in in site admin).
To use a WMS map from another server in MapGuide, instructions are here:
http://trac.osgeo.org/fdo/wiki/FdoWmsNotes
Well... Those are advanced instructions, for most usage, you can just
add a new WMS featuresource.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andre Schoonbee skrev:
> I have 2 questions relating to WMS:
> a) How to I publish a map already defined using Studio 2009 as a WMS map
> b) How do I load a layer or another map from another server, published as a
> WMS map service.
> Andre
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
