[mapguide-users] How to publish map as WMS
Kori Maleski
kori.maleski at gmail.com
Tue Nov 11 12:59:01 EST 2008
The parameter details are available in the mapagent web tier tests
under WMS:
http://localhost/mapguide/mapagent/index.html
Normally the URL will be something like the following:
http://localhost//mapguide/mapagent/mapagent.fcgi?service=WMS&REQUEST=GetMap&VERSION=1.1.1&LAYERS=Places&FORMAT=image/png&SRS=EPSG:4326'&bbox=bbox&width=width&height=height
Cheers,
On Tue, Nov 11, 2008 at 10:02 AM, Pedro Venâncio
<pedrongvenancio at yahoo.com>wrote:
> You simply right click the layer, and under properties there is a
> "Service" or "WMS" entry.
> There you must enable the layer as a WMS layer, and set some properties.
> After that, you should be able to pass the regular MapGuide URL to an
> WMS enabled service:
> Hi Kenneth
> I've done that but I don't know the full URL to use. (Layer name is
> "Places").
> Regards,
> Pedro
> --- On *Tue, 11/11/08, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>*wrote:
> From: Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>
> Subject: Re: [mapguide-users] How to publish map as WMS
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Date: Tuesday, November 11, 2008, 10:51 AM
> In MapGuide, you publish a layer, not a map (unfortunate IMO).
> http://server/mapguide
> (And WMS must not be deactivated in in site admin).
> To use a WMS map from another server in MapGuide, instructions are here:
> http://trac.osgeo.org/fdo/wiki/FdoWmsNotes
> Well... Those are advanced instructions, for most usage, you can just
> add a new WMS featuresource.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andre Schoonbee skrev:
> > I have 2 questions relating to WMS:
> > a) How to I publish a map already defined using Studio 2009 as a WMS map
> > b) How do I load a layer or another map from another server, published
> as
> a
> > WMS map service.
> > Andre
> > mapguide-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081111/3693a508/attachment.html
