[mapguide-users] Request.QueryString Fusion 1.1
Paul Spencer pagameba at gmail.com
Wed Nov 12 08:29:43 EST 2008
Hi Brian, sorry I was out of the mailing list loop for a few days and
am just getting caught up - didn't mean to ignore you.
If you are using Fusion 1.1 then there should have been no substantial
changes that would affect this and so it should still be supported.
If its not working then there is likely a bug.  Can you describe a bit
more what you are (not) seeing - it seems like you are using the
TaskPane?
Paul
On 7-Nov-08, at 9:13 AM, Berdel, Brian wrote:
> Thanks Jason, I will try that out.  I was using server side code and
> this worked in all previous releases.  Now the entire array is empty
> so I was wondering if one of the fusion developers could chime in
> and let me know if it is still supported, if it is a bug, or if
> there is another way to attain these server side… I really like the
> new version it fixed a lot of other issues but my apps are all based
> on server side code retrieving these parameters.
> Brian
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org
> ] On Behalf Of Jason Birch
> Sent: Thursday, November 06, 2008 4:50 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Request.QueryString Fusion 1.1
> See if Fusion.queryParams contains what you want.
> On my map it is showing with properties for each of the parameters,
> as well as methods to iterate them, etc…  This is just from what I
> can see in FireBug; not sure if there are any docs on it.
> Jason
> ] On Behalf OfBerdel, Brian
> Sent: Thursday, November 06, 2008 12:32
> Is this still supported? My parameter array returns none from
> request.querystring.
> Thanks,
> Brian
> Hello all,
> I was previously able to get parameters such as mapname”MAPNAME” and
> sessionID “SESSION” through request.querystring…
> Now I get nothing…Any thoughts?
> Thanks,
> Brian
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
