[mapguide-users] Maps not visible in MgOS 2.0.2
MacNair
manoj at deltacadd.com
Thu Nov 13 08:22:41 EST 2008
Let me recollect...OK here we go.
I was successfully running MGOS 1.2 with maps authored on MGE2008. I removed
this and installed MG0S 2.0.2 instead, as we began authoring the maps on
MGE2009. MGOS 2.0 windows installer failed to create & configure the virtual
directories for me (though I opted for it). Not sure why? Maybe I had to
stop MG 1.2 service before uninstalling the previous version of MGOS server.
Did try some manual configuration and didn't succeed too. I then borrowed
these configurations from some other server using .config files and that
helped. The .config files were borrowed from a server where a fresh
installation of MGOS 2.0.2 was done with no previous versions of MGOS
running on it. Saved a lot of time figuring out what’s wrong.
The open source installations were all done at default locations in
"C:\Program Files...." blah blah blah!.
Removed "Windows Authentication" for "mapguide" application and the other
virtual directories inheriting the same. (I did this as the borrowed .config
had them checked. Turned them off!
Renamed the Sheboygan package to .MGP from .ZIP. Placed it in "Packages"
directory at "D:\SomeWhere\Packages". This is where the "Package" location
is configured using "Site Administrator". Loaded the package successfully.
What else? Hmmn..
Created "dotnetviewersample" application under "mapguide" pointing to
"C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\dotnetviewersample".
Copied "*.dll" from "mapviewernet" bin directory to " dotnetviewersample"
bin directory.
That's it. Eureka! Good luck to you and hope this helps.
Kimmo Kotajärvi wrote:
> I might be having the same problem, using MGE2009 + MGOS2.0.2 on IIS here.
> I can't see Sheboygan's map, but all the layers are listed correctly. How
> did you solve the problem?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of MacNair
> Sent: 11. marraskuuta 2008 17:20
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Maps not visible in MgOS 2.0.2
> Yes! Sheboyagan worked followed by my Maps too. Permissions to a few
> virtual
> directories were not set correctly.
> Thanks Andy!
> Andy Morsell wrote:
>> Do the sample maps from the Sheboygan sample dataset work? If not, then
>> it
>> looks like an IIS and MGOS installation and configuration issue.
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> www.SpatialGIS.com
>> Sent: Monday, November 10, 2008 9:50 PM
>> Subject: [mapguide-users] Maps not visible in MgOS 2.0.2
>> Am unable to view maps (authored in Mge2009 Studio) via our Mapguide
>> application with Maguide Open source 2.0.2 Server. The viewer gives a
>> blank.
>> However, we are able to view the maps through our application with Mge
>> 2009
>> server though.
>> These maps have the following data authored...
>> 1. Themed layers
>> 2. Feature joins between SDF and SQL server table.
>> I was able to view these maps previously (authored in Mge2008 Studio)
>> with
>> using Mapguide open source 1.2. I recently installed Mapguide open source
>> 2.0.2 to try the maps authored in Mge2009. The open sources Windows
>> installer didn't create the virtual directory at the end of the
>> installation. I did it manually and configured the application in IIS.
>> The
>> installation was done on Win2003 SP2.
>> Suggestions are welcome. Issues with application configuratin in IIS
>> which
>> I
>> did manually?
>> Thanks and Regards!
>> View this message in context:
>> http://n2.nabble.com/Maps-not-visible-in-MgOS-2.0.2-tp1483925p1483925.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Maps-not-visible-in-MgOS-2.0.2-tp20433988p20441704.html
View this message in context: http://www.nabble.com/Maps-not-visible-in-MgOS-2.0.2-tp20433988p20480728.html
