[mapguide-users] Displaying points of given GPS coordinates
Carmelo Saffioti
csaffi at libero.it
Tue Nov 18 04:33:52 EST 2008
I created the WEB-INF/lib directory on the App-specific directory,
then I copied the json.jar file to the MyApp/WEB-INF/lib directory.
Now it works without compiling errors :-)
Regarding samples about dynamic creation of points of interest, are you
talking about the viewersample (ajaxviewersample.jsp) ?
Is it good for displaying points on the map with given GPS coordinates?
I need also to trace routes lines which connect a sequence of GPS positions.
Is it possible?
Cheers
Carmelo
----- Original Message -----
From: "Mauricio Villablanca" <mgvillablanca at yahoo.com>
To: <mapguide-users at lists.osgeo.org>
Sent: Saturday, November 15, 2008 8:20 AM
Subject: Re: [mapguide-users] Displaying points of given GPS coordinates
> Look at the samples. One of them shows how to dynamically create points of
> interests.
> Carmelo Saffioti wrote:
> > Hi everybody,
> > I successfully imported into MapGuide my planimetry exported as SHP and
as
> > SDF. I need to display on the map some GPS points which have a lat/lon
> > coordinate. The map coordinate system is LL84 (WGS84), therefore the
> > coordinate system should be the same for these GPS points and for the
map.
> > How can I do to display points with given coordinates on the map? Is
there
> > any example or tutorial or other?
> > Thank you in advance
> > Cheers
> > Carmelo
> > mapguide-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.nabble.com/Displaying-points-of-given-GPS-coordinates-tp20479019p20513108.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
