[mapguide-users] Problem whit select
Miguel Santiago Vasquez Alave sgds_sig at munisurco.gob.pe
Wed Nov 19 10:36:29 EST 2008
Hi i have configurate MGOS 2.0.2 whit .Net and IIS, i try to make application but when i try to use the example to find a feature like a parcel whit id i have problem i run this code and dont have error but the xml select dont return nothing because is null only show the head of xml. I change the call of GetGeometry method whit "Geom" in the example is "Data" because i dont have "Data" attribute whit geometric i have "Geom" whit geometric attribute. The layer is a SDF i build it whit autocad map 2009 and firts its a shape file and i convert to SDF to use whit MGOS.
using System;
using System.Data;
using System.Configuration;
using System.Collections;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using OSGeo.MapGuide;
using System.Collections.Specialized;
using System.Text.RegularExpressions;
public partial class gis_ubicacion_GISFrmInformacionLote : System.Web.UI.Page
    protected void Page_Load(object sender, EventArgs e)
        NameValueCollection requestParams = Request.HttpMethod == "GET" ? Request.QueryString : Request.Form;
        String mgSessionId = requestParams["SESSION"];
        String mgLocale = requestParams["LOCALE"];
        String mgMapName = "mss_map";
        String realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
        String configPath = realPath + "..\\webconfig.ini";
        MapGuideApi.MgInitializeWebTier(configPath);
        MgUserInformation userInfo = new MgUserInformation(mgSessionId);
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        MgMap map = new MgMap(siteConnection);
        map.Open(mgMapName);
        MgFeatureQueryOptions districtQuery = new MgFeatureQueryOptions();
        districtQuery.SetFilter("IDLOT = '40010101'");
        MgLayer layer = map.GetLayers().GetItem("lay_lote") as MgLayer;
        MgFeatureReader featureReader = layer.SelectFeatures(districtQuery);
        featureReader.ReadNext();
        MgByteReader districtGeometryData = featureReader.GetGeometry("Geom");
        MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
        MgGeometry districtGeometry = agfReaderWriter.Read(districtGeometryData);
        MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
        queryOptions.SetFilter("IDLOT = '40010101'");
        queryOptions.SetSpatialFilter("SHPGEOM",districtGeometry,MgFeatureSpatialOperations.Inside);
        featureReader = layer.SelectFeatures(queryOptions);
        MgSelection selection = new MgSelection(map);
        selection.AddFeatures(layer, featureReader, 0);
        String selectionXml = selection.ToXml();
        litSelectionXml.Text = Server.HtmlEncode(selectionXml);
        hfSelectionXml.Value = selectionXml;
Pd. Sorry for my english i speek spanish.
Miguel Vasquez
Especialista GIS
Municipalidad de Santiago de Surco.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081119/1eb89ab5/attachment.html
