[mapguide-users] New King.Oracle 0.8 - improved performance
Haris Kurtagic haris at sl-king.com
Wed Nov 19 11:39:05 EST 2008
Yes, I would guess it is wrong extent in layer preview.
As Dave suggested set manually extents in the map and try it.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Wednesday, November 19, 2008 5:10 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] New King.Oracle 0.8 - improved performance
If a layer preview fails you should generally add that layer to a new
map to see if the extent information and coordinate system are set
correctly. Often times the extent values are not correct.
Regards,
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonio,
Dennis (Aviation)
Sent: Wednesday, November 19, 2008 9:04 AM
Haris,
MGOS 2.0.2 on MS2003 Server, using MG Studio 2009 for the rest of it.
Installed your .8 release.
Feature Source
            Connection ... OK
            Set coorsys Override... OK
            save ... OK
Create Layer:
            Fetched all 200+ Feauture Classes ... OK
            Properties.. OK
            Layer Preview:
                        a)nothing ... should have 20000+ geometries in
one of the selected feature class'
                        b)tried a bunch of different tables ... nothing
I don't get any errors logged anywhere that I can find.
I had downloaded and installed the instant client that was discussed
previously. Obviously we are making connection because you are getting
the list of Feature Classes.
I did both the Override thing and I also tried without the Override
thingee(It was populated correctly)
r,
dennis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081119/69a9dc76/attachment.html
